CareTaker Plus Security system
I have a CareTaker Plus security system that was installed in 1993. The alarm system beeps rapidly six times indicating a low cpu battery. I replaced the system 12 Volt battery but It still beeps at 11:00 pm every night. I keep pushing different codes and it stops until next day at the same time. I could not find a dealer to help me yet. So if you have any suggestion, would you please tell me what to do to solve this problem?
Thank you
Thank you
You will not find a dealer for this system. It has been out of production for quite a while.
Also, if this is a ITI Caretaker Plus, then the battery should be a 6volt 3.2ah battery, not a 12volt. If you installed a 12v battery, then that may be your problem.
Thank you for your reply. It is ITI system and the old battery that I replaced was 12 Volt 7.0 AMP. I think GE bought ITI but you are correct I have a difficult time to find a dealer. Thanks
