FA1600C locked out.
FA1600C locked out.
Hello,
I have an alarm panel FA1600C locked out, I powered down and up, press * and # with 30 seconds to go to programming mode, but did not do anything still locked out. Can anyone assist? Thanks in advance
You can try having someone hold * + # while you restore power.
It is possible that local programming was disabled using the download software. If so, I don't know the workaround for this.
If you can find out the company that installed it, you might be able to get them to unlock the panel for you. Ask them to default the CSID, and the account numbers, installer codes, etc, and leave it unlocked so you can get into programming after that. They might be willing to do it.
