System check
Old 05-14-07, 05:38 PM
A
aro
aro is offline
Received 1 Upvote on 1 Post
System check
Hello,
I have a little over 5 year old house. Few weeks ago I have noticed that the system check light on the control was on. I have pushed the button with the check mark to see what the problem is and the zone 2 light started blinking and it was beeping nonstop. I guess the problem is some how related to zone 2 (the garage door). However, when I open the garage door, the light indicating that door is open still works. Also, I still can arm and un-arm successfully. Is there anything that I can check on this? Please let me know and thanks for your help.
Links to images:
http://img239.imageshack.us/img239/4219/image001kh8.jpg
http://img239.imageshack.us/img239/8228/image003nv4.jpg
http://img239.imageshack.us/img239/6734/image002ru7.jpg
Old 05-14-07, 06:48 PM
U
From reading the information on your keypad door I would say you have a low battery. you need to replace the UB1245 battery in your panel. this will take care of your system trouble.
these batteries will last about 4 to 6 years depending on the system.
You should be able to get one at your local battery supply store.
Old 05-14-07, 07:58 PM
A
aro
aro is offline
Thank you for replay.
I have searched on internet for UB1245 battery, including local store inventory and looks like they don’t have exact model, but have compatible replacement battery. I assume it should work. Should I power off to replace the battery? Thanks again for your help.
Old 05-14-07, 08:04 PM
U
you should not have to power down to replace the battery.
Just make sure the replacement is a 12v 4.5 amp hour battery.
Old 05-14-07, 08:05 PM
Received 265 Upvotes on 244 Posts
You don't need to power down. The batteries aren't specific. Most alarm systems will charge any battery up to about 12ah without a problem.
Old 05-15-07, 04:47 PM
A
aro
aro is offline
I have replaced the battery, but the trouble light is still on. I have tested the old battery and it had only 7 volts, so it needed to be replaced. Is there anything else that I can check? Thanks again for your help.
Old 05-15-07, 05:52 PM
HotxxxxxxxOKC's Avatar
Might give it some time. Most sytems only do a battery check test once a day or every few hours.
Old 05-17-07, 12:59 PM
A
aro
aro is offline
Trouble light is off. Thanks a lot for your help.
