Please help with Vista 20p
  #41
Old 06-25-07, 08:16 AM
A
No more ideas? Please guys! i need help
  #42
Old 06-25-07, 05:58 PM
Received 265 Upvotes on 244 Posts
At this point, there is insufficient information to provide you with a meaningful answer. The "just numbers" on the 6128 actually have meaning for most of the programming areas. It's only the menu programming areas like *56, *80, etc. that is not useful for.
What does the 6128 display when the 6270 is showing "panel busy"?
You have the reference material. You are looking at the displays, we can't. Playing "20 questions" for every step will not help you learn this programming syntex.
What keystrokes were you entering when the system choked on you?
All of this stuff is important, otherwise, you might as well use the 6128 to enter *96 and start over, this time applying the things you have already learned.
  #43
Old 06-28-07, 03:41 PM
A
Alright, i reseted as you suggested and although it did not reset it allowed me to continue and fixed the problem, thanks!
now i have a little anoying one.
I have two window/door sensors. And everything is fine until they go off, after they went off they stay in fault and cant get them out of there unless i unplug the alarm
thanks!!!
alex
And i also have a keyfob wich i failed to make work.
everything else so far so good (until i try to make the alarm call my phone)
  #44
Old 06-28-07, 04:12 PM
A
PS: Are the motion sensors suposed to be Zone 1? bc everytime i walk around the keypad makes an annoying beep
PS: I would have edited the msg i posted before but the board doesnt let me
Thanks for everything guys! this would have been impossible without your help
  #45
Old 06-28-07, 07:15 PM
Zones are programmable. If you set zone one as an interior zone (it defaults as a fire zone) you might have better results.
Check the zone types you have your zones for. The wrong zone type will get you odd behavior. It's really not a complex concept.
