DSC PowerSeries PC5508Z-Bypass Zone
Old 06-07-07, 07:56 PM
L
Hi...I'm hoping to find the answer to a question that ADT cannot answer unless they send out a tech at the cost of $100+
Our system is only 3 years old. All zones worked at one time. When my husband left for Iraq, I tested all zones to ensure everything worked as it should so I know that the downstairs windows were activated. However, at this time the system indicates that the windows are bypassed. I called ADT and they walked me thru all of the steps that should erase all bypass zones. That did not help. When I set the code as if nothing were going to be bypassed, the panel indicates a bypass and windows are not activated. I can set the alarm and all zones are active except windows downstairs. All other zones work except downstairs windows.
We had an electrical storm a few weeks before I found out that the windows were not activated. There were several lightening strikes near the house and power was out for hours at a time. Is is possible that the storm somehow affected the alarm system?
I am just looking for an idea of things that I might try before I have to call ADT for service
Thanks and I look forward to any help.
Old 06-08-07, 04:47 AM
Received 265 Upvotes on 244 Posts
Your windows are likely connected to a zone that has been set as an interior stay/away zone. I'd be willing to wager that if you set the chime feature on, and open a window in this zone it doesn't chime, and if you arm the system, then open and close an entry/exit door during the delay countdown, the zone will not auto-bypass.
It's an easy fix, but it's something that should have been caught at the initial system configuration. I'm guessing that when your spouse was home, you seldom if ever armed the system except when leaving.
Old 06-08-07, 07:16 AM
HotxxxxxxxOKC's Avatar
On a different note:
I'm active duty military right now and have served overseas numerous times. My thoughts and prayers are with you and your family while your husband is gone.
Let us know if you need anything!
