Focus 75 panel
Focus 75 panel
Hi
I would like to know the default installer code for FOCUS 75.
Thank you in advance
Wow, this sounds like a ADT proprietary panel which makes getting these codes difficult if not impossible.
Look inside the main panel on the motherboard. There should be a chip on the board that states something like this: PCxxxx
What is that number?
The Focus 75 was a specially modified panel made by Ademco for ADT. You can try the typical ADT installer code, but it's hard to tell what the base board is to advise you any further. If it was made by Ademco, look for a model number on the PC board base itself, usually on the upper edge. It may begin SAV xxxxxxx.
I was able to go to zone 74 and disable it after I got check dialer 1 , is that mean the dialer is not locked and can be monitor by any company?
Thanks again for your help guys
No that is just zone programming. You took out the supervision for the dialer 1. I am unsure as to where the phone numbers go in this panel. Try looking at fields 31,32,33,34,35. Two of these will probably be primary and secondary phone numbers. I am basing this on it being a Vista 128 or 250 clone for ADT. If none of those work try fields 41,42,43,44. Keep us posted. Oh and assuming the programming is similar to the regular Ademco, you will press the # and then the field number to view it's contents. Good luck.
even though you may get to the programming for the phone numbers the dialer can still be disabled. They do this via downloading software. The only way to tell is to program your cell phone number in the primary phone field and set the alarm off and see if it dials. Oh and don't forget to hook the phone line to it.
