How to Delete Zones
Old 07-09-07, 02:28 AM
A
Unhappy How to Delete Zones
i want to delete 2 zones from my admeco (honeywell) vista 12.
can someone pls help, how can i do this. i am fimiliar with programming but could not figure it out how to get rid of these 2 zones form system.
i have disconnected them and both waires are disconnected from pannel as well.
i have tried to restart few times completely from battery, too. but it is not able to go in Ready , it says not ready and then zone 5, 6.
Old 07-09-07, 04:10 AM
D
Instead of trying
to delete them from the programming, why not just use a jumper wire right at the alarm panel to disable these zones? A short piece of wire from the common to each zone.
This way the system will think they're constantly closed.
If a jumper wire doesn't work, you may need to connect a resisitor to the zones instead. The exact value will vary between different makers and models though.
I hope this helps!
Old 07-09-07, 06:04 AM
A
thanks Desy, worked like charm.
Old 07-09-07, 06:28 AM
A
strobe temper connection?
can someone plz tell me where should i connect temper connection from external strobe/siren in vista12 pannel.
would it connect as a seperate zone? or in some other way, thanks.
Old 07-09-07, 03:32 PM
SameBIG CHIEF's Avatar
I take it you mean tamper. The tamper is optional, and if you choose to use it you will need to kook it to an empty zone on the control panel.
Old 07-09-07, 03:54 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Chief,
Glad to see you in the forums! I'm sure MrRon was overwelled everytime he logged in.
Old 07-09-07, 04:20 PM
A
thanks SameBig Chief.
