Vista 20P zone expansion
Old 07-28-07, 08:01 AM
Will the 4208U zone expansion module work with my Vista 20P? I see in the manual the instructions for the 4219/4229. Are those the ONLY modules compatible? As always, Thank You!
Old 07-28-07, 07:07 PM
Received 24 Votes on 23 Posts
The 4208U is specifically listed as _not_ compatible with the Vista 20p (or any of it's cousins like the 10P or 15P)
Old 08-06-07, 04:10 PM
Thank you. One more question - Can I add a motion sensor on the Vista 20P zone expansion module? And if so, is there any special programming or do I just set it up as "NC"? Thank you
Old 08-06-07, 07:13 PM
A standard motion detector is just a normally closed relay with a motion sensor to turn it on and off. It will work with any hardwire zone input as long as you supply 12 vdc for the thing to work.
