SW3000 - Burglary Dialer Delay
Old 10-09-07, 07:19 AM
C
Hello, I have a ADT Safewatch 3000 (no longer with ADT) which I'm trying to modify the Burglary Dialer Delay (*50). When I set this to 0 - no dial delay, the delay defaults to 30 seconds. When I set this to 1 - 15 seconds, the delay changes to 15 seconds. Did ADT lock out the ability to set the Burglarly Dialer Delay to 0? If so, is there a way to get around this restriction in order to set it to 0 - no dialer delay?
Thanks!
Old 10-09-07, 09:53 AM
Received 241 Votes on 220 Posts
I would have to check, but the dialer delay may be hard coded in the ADT variant of the Vista 20p/SW3000.
If you entered *50 0 and it went back to a 2 when you checked with #50, then it may well be 15 seconds as a minimum delay. ADT sets a lot of defaults that "enhance false alarm prevention".
Old 10-09-07, 10:14 AM
kcxj's Avatar
This is one field that canot go below 15 secs. Also, you cannot remove the exit warning beeps on this panel.
Old 10-12-07, 01:16 PM
C
Thanks
Thanks for the information.
Craig
