Ademco Vista 20 would this water sensor work
Old 10-11-07, 04:37 PM
C
Received 1 Vote on 1 Post
would the below water sensor work with a vista 20? Does it just get wired like a sensor? Do most monitoring companies have the ability to have them call someone other than the authorities should this trip
http://www.homesecuritystore.com/ezs...8&bViaAC=False
Old 10-11-07, 04:55 PM
kcxj's Avatar
The sensor will work if you have an available hardwired zone. The zone needs to be programmed as a 24 hour supervisory. Most central stations will only call a contact list on this type of alarm. I did see once, when working in a CS, that a customer had a contact # to call the oil company to fill the oil tank when a freeze alarm occured.
