entry delay pc1550
Old 10-13-07, 03:43 PM
A
entry delay pc1550
hi, i have a pc1550 that i have reset back to defaults. the entry delay default is 45 sec's. i have entered a new user code and everything works fine but i want to change the entry delay to 15 sec's. i have downloaded the user/program manuals but i dont understand how to reset the delay if sombody could tell me what codes to push. my door is on zone 2
Old 10-13-07, 04:08 PM
Integrator97's Avatar
It's in the installer programming. look for a section called "system timers". This should be entry delay 1. You zone 2 is already programmed as a delay door.
Old 10-13-07, 08:14 PM
Received 241 Votes on 220 Posts
On a PC 1550, that's location 17. It's one of the odd ones, because it's the only one where there are 3 digits in each segment instead of 2.
Go to program
enter 17
enter 015 060 004 030 050 030
(this sets entry delay to 15 sec, exit delay to 60 seconds, and leaves all of the system times at the factory default settings)
Press # until you exit programming.
There are a couple of the very oldest versions of this system that have a slightly different scheme for this, but this covers 90% of the PC1550s out there.
