Adjust Ademco 6150 Backlighting
Old 10-17-07, 06:56 PM
Hello,
I have 2 Ademco 6150 keypads. 1 in my basement stays fully illuminated (the keypad and the screen). The other, in my bedroom, the keys stay litbut the screen itself only comes on once I press a button, and it only stays on for 1 minute before going dark again.
How can I access programming that will allow me to have this keypad stay fully illuminated-keys and screen- all the time?
Thanks in advance for any help!
Old 10-17-07, 08:36 PM
Received 38 Votes on 37 Posts
What system model are the keypads attached to? The answer varys by system model.
Old 10-18-07, 07:28 AM
Im sorry- The system is a First Alert, Model FA168C-GP.
Hope that helps. Thanks for your response.
Old 10-18-07, 05:02 PM
On the system you have (a modified Vista 20p), there is no adjustment for that feature. The keypads normally turn off the display backlight after 30-40 seconds or so.
The only variable to this is a setting for displaying the exit time countdown.
It is possible that the one staying lit is actually the one malfunctioning.
Old 10-18-07, 06:13 PM
Thank you very much. If I replaced the keypads with a different model/brand would that help, or am I looking at replacing the main circuit board?
Old 10-18-07, 08:17 PM
No, other than upgrading to one of the (much more expensive) graphic keypads, you have pretty much the same specs.
Really, there's not adjustment for this feature without completely changing your system out for a higher end system. You just got the luck of the draw and got one abnormal keypad (the one that stays backlit). Normally they _all_ power down the display backlight after awhile.
Old 04-15-08, 06:59 PM
Can anyone tell me the difference from a First Alert FA168C-GP and a Ademco Vista P?? How do you tell how old the system board is? Should these come with the battery for standby or is that normally purchased separately?
Thanks for all the help
