System Sensor 2WTA-B, need more info.
Old 10-26-07, 11:13 PM
Just how do these detectors work? The installer says that there will be a separate panel for them, but if I have a two story house, how do the people upstairs turn them off?
Anyone ever use them before?
Old 10-27-07, 02:18 AM
And exactly is low voltage?
Old 10-27-07, 08:03 AM
Received 286 Upvotes on 263 Posts
For specifics of the detectors themselves, go to www.systemsensor.com.
These are "system" smoke detectors. To work, they have to be connected to either a fire alarm control, or a compatible security system control. They are powered by the system power supply and backup battery, so there's no individual 9v batteries to mess with. This model has a thermal sensor and a built in sounder in each individual unit.
They are low voltage because the run on 12-24vdc.
Old 10-27-07, 12:19 PM
Integrator97's Avatar
And they are turned off from the security or fire alarm keypad (you can have more than one). They are designed to be wired, so that if a smoke detector goes into alarm, they all sound.
You say 2 story house. You don't mean a 2 story duplex do you, with one unit up and one down?
