adt check zone 09, zone10
Old 11-01-07, 08:20 PM
R
Please help I'm having a problem with my adt alarm it keeps giving me a check zone 09 and zone 10 does anyone know how resolve this?
Old 11-01-07, 08:34 PM
Received 288 Upvotes on 265 Posts
Not knowing what model you have, I'll guess that it's having a problem communicating with your wireless receiver (check 09) and one or more of the transmitters. The answer does vary a bit, depending on which system you have.
Old 11-02-07, 06:42 AM
R
alarm problem
It's an Ademco 4110dl or 4110xm I believe. but yes it has wireless on it. How do I dissable the wireless compleatly? I don't use it anyway. Also I would like to change the code and erase the code of 1234. I found the 1234 code online and it worked so I could test and set the system. However I would like my own personal code.
Old 11-02-07, 08:28 AM
R
I had a safewatch 2000 but just 5 min ago I changed it back to the old alarm a Vista 10SE that the previous owner had in so disregard the wireless issues and now I have a new one. Everything is on except the bat and I'm receving a check 05 however there is nothing connected to 05? I installed a resistor on it but no luck. Also same problem with the alarm code 1234 need to change and deleat so that I can secure and don't know previous owners code they are in an oldfolks home with alzheimers disease. Also wont let me bypass 05.
Old 11-02-07, 04:29 PM
You need the installer manual: http://nassausecurity.com/ademco/v10seim.pdf
and the programming manual: http://nassausecurity.com/ademco/v10sepm.pdf
Could that zone (5) have been used as a fire zone on the previous installation? Fire zones cannot be bypassed.
In any case, if bridging it with the correct size resistor (1k ohm --brown black red for the first 3 stripes), doesn't close the zone, then the zone input may be damaged, and there is no fix for it.
Old 11-02-07, 06:46 PM
R
good call
correct 05 is for the smoke alarm but after i hooked it up i powered it down then when i brought it back up i got fl i code then off now zones 01,02,03,04,06 all show to be not read however nothing hooked to 02,03,04,06???
powered down same thing again.
how many things need to be on 1 zone?
can i have only 1 thing(window?,motion?,door?etc.) on a zone?
how many things(window?,motion?,door?etc.) can i have on a zone?
Old 11-02-07, 07:12 PM
R
??????adt vista 10se
on an adt vista 10se 05 is for the smoke alarm but after i hooked it up i powered it down then when i brought it back up i got fl code then off now are zones 01,02,03,04,06 all show to be not read however nothing hooked to 02,03,04,06???
how many things need to be on a zone?
