Ademco Vista 10SE with "OC"
Old 12-11-07, 07:49 PM
3
Got the house with Vista 10SE, no code. It kept beeping until I hit any key to stop then it came back again somtime later. I unplug the battery and power for a year. Now there is a rash of break in in the neighbor. Plug back battery and power. One beep on keypad M6128 (but found the number M6673 on the flipout keypad cover) then "OC" on display. Press * + #, nothing. There are lights on all 3 keypads. Did I mess up the console? Did my battery run out of juice? I was trying to get installer code and set up in house alarm. Please help. Thank you.
Old 12-12-07, 05:19 AM
kcxj's Avatar
OC indicates a break in the data wires from the panel to the keypad. Release the keypad from the back plate and make sure all wired connections are secure. Also, check at the panel to verify that the connections there are good as well.
Old 12-12-07, 06:46 PM
3
One of 3 keypads wirning is "OC"
After checking all 3 keypads, one is OC. I took that one out. Now it shows "d1". Hook up battery back, got 20. Then follow the info from this great forum, able to get installer code. Put in new code, Alarm works!!!!!!!!!!!!
Now I see 10SE has antenna stick out, might be I can add wireless?? How do you tell that you get wireless?
Thanks again for get help.
Old 12-12-07, 07:54 PM
Received 265 Upvotes on 244 Posts
If there are antennae, then you have a wireless receiver. Look at the smaller of the two boards in the system cabinet, it will have a number on it like 5881L, M or H. That last letter tells you how many devices the receiver supports for this system.
Old 12-13-07, 06:14 AM
3
Thank you RonFL. I will take a look tonight. Plan to replace one keypad with 6160. Is there any better keypad? and if the system has wireless I will add more wireless sensor to more doors. Thanks again. So happy that the Vista 10SE working again.
Old 12-13-07, 08:32 AM
Nope, for a V-10se, the 6160 is about as good as it gets, and you need one if you plan on changing any zone programming.
Old 12-14-07, 11:06 PM
3
I have 5881M. I will need 6160. Just bought 2 extra wireless 5816 door contact. What is the different 6160, 6160v, red 6160CR? Thank you.
Old 12-15-07, 06:40 AM
The "V" model has a voice chip and has a limited vocabulary to audibly announce the stuff the keypad displays (trust me, you will turn that voice feature _off_ in a month, it's actually kinda annoying). In my opinion, its of use primarily for the visually impared.
The "CR" is intended for use in situations where the alarm system is being used as a light duty fire alarm as well as a security system (with the right add on devices, it meets the criteria for a commercial fire alarm).
Old 12-15-07, 10:46 AM
3
Thumbs up
Thank you. I just bid on the Bay for both 6160V and 6160CR. Hopefully I win one so that I can edit the phone number and add wireless door contact. Thanks again for great help.
Old 12-15-07, 04:48 PM
kcxj's Avatar
6160CR is a red unit. Ok for programming, but you may not want in your house.
Old 12-19-07, 08:01 AM
3
What is keypad 6160SNA?
Old 12-19-07, 10:15 AM
Probably a 6160 with a specific company logo on it. On a guess, SecurityLink North America.
