GE Networx with NX-1300E LED keypad
Old 04-12-08, 01:22 PM
I am trying to make the keypad chime in the dissarmed mode when an entry door is opened. one door chimes now but I would like to have 2 more doors chime. The system was already installed when the home was purchased. Have an arm and disarm code.
Old 04-13-08, 08:02 AM
You'll have to go into programming and change the zone type or zone configuration in order to make those other doors chime...Not a user friendly option with the type of keypad you have.
Old 04-13-08, 12:53 PM
Received 38 Votes on 37 Posts
A more important question: Do these doors even _have_ contacts?
Unless someone did some unusual programming, _all_ perimeter and entry/exit zones for these systems chime by default (when chime is turned on).
Old 04-16-08, 11:29 AM
Contacts in I was wrong about arm and disarm code we have none. So i guess im starting from scrach. also found out that Zone 1 light flashes. Panel says zone one is entry no motion just door contact.
Old 04-16-08, 01:41 PM
OK More info on the nx-1300 By reading all other post I do have a code as factory 1234. zone 1 is flashing and i can not clear it by using (*) - (7). Zone 1 is an entry with a magnetic button in door frame for a metal door. How can i clear zone 1 and set alarm. I can not even by pass this zone and the manual does not explain how to force arm the system.
Old 04-16-08, 05:08 PM
Check to see if there is a matching magnet in the door. If it is in place, it may simply been misaligned. (Often people replace doors and forget that little magnet plug in the door header)
*7 is not the bypass command on a NX system
You press the bypass key, the zone number, then you press the bypass key twice.
This is a pretty common system; the user manuals are readily available.
Old 04-17-08, 03:33 AM
Thanks for the help on by passing a zone. The front entry door is the one that is giving me trouble. Zone 1 steadily flashes on the keypad which will not alow me to arm the alarm. the manual tell me that i can clear a zone by (*)-(7). I tried this but nothing happens it still flashes. am i missing an a step before or after i push (*)-(7)? The front door is metal. Is a little magnet plug still needed?
Old 04-17-08, 05:34 AM
Yes, there has to be a matching magnet for the magnetic reed switch to close.
*7 is the reset command for _smoke detectors_.
Take a refrigerator magnet and hold it to the contact. If the zone closes you are just missing the magnet. If it doesn't then either the contact or the wiring is bad.
