Help with Programming a Vista 20P - Please
Old 04-20-08, 08:42 PM
Hi, I have a vista 20p (rev. 3) and a 6160 keypad. I am trying to program field #24 RF House ID CODE but it only seems to accept 1 number in that field. If I type 17 for example, it will show me the last digit and change that to a "1" then if I type "7" it changes the last digit only to a "7". So I can't program a 2 digit code. Including 00 the one to disable the wireless.
Does anyone have any ideas?
Thanks.
Old 04-20-08, 09:04 PM
Received 36 Votes on 35 Posts
Are you sure you are in the correct field?
There's no voodoo to this. You go to program and enter *24 0 0, and it should beep and jump to the next location.
What happens if you key in #24?
It should show you the current contents, 1 digit at a time.
Old 04-20-08, 09:17 PM
I seem to be able to turn the RF device off by punching in 00 somehow finally it took but it took a lot of horsing around in there. However, I still have a problem. I can't get my wireless device to work. I posted another topic for this, its located:
http://forum.doityourself.com/showthread.php?t=342803
Thanks
