Easy one : DSC PGM output voltage
Received 0 Votes
I have a PC5010 DSC panel rev 03. Is it possible to program the PGM output voltage? If not, what is the voltage of PGM1 et PGM2 ?
Thanks
Michel
Thanks
Michel
With normal programming, the PGM terminals are a switch to ground. The positive voltage comes from the Aux power on the panel. You can "invert" the output on the PGMs and have them put out +12vdc, but their current limit is pretty small in that configuration.
Just curious....What are you trying to do with the pgm? I sometimes use it to trigger a relay which in turn trips a voice dialer. A lot cheaper than paying monitoring forever. Just curious...
