Ademco 4219 vs 4229 ???
Old 05-02-08, 09:51 AM
Hi, I am brand new to security systems!
Can anyone explain the difference between the Ademco 4219 the 4229 Zone Expanders?
What are the Prograble Form C Relays for??
How do they work?
I am planning new wired system and want to get the right components the first time!
Thank You!
Old 05-02-08, 10:48 AM
Received 35 Votes on 34 Posts
The 4229 has relays on it to allow you to control external devices, or do things like reset the power for a 4-wire smoke detector loop. "Form-C" means that the each relay is single pole - double throw (SPDT) and can be normally open or normally closed, depending on which terminals you connect the wires to. (Form A is SPST normally open, Form B is SPST normally closed)
In this case, the relays can be programmed for a wide range of actions.
Old 05-02-08, 11:34 AM
Thanks that clears up the mystery and helps with the decision! Thanks Again!
