ADT system - How to get function w/o ADT service?
Old 05-03-08, 02:58 PM
Cool ADT system - How to get function w/o ADT service?
I have a neighbor that bought a winter home here in Fla. 2 years ago. It has an ADT alarm system but never used it. We just powered it back up and it seems ok. Has a 6150 Honeywell keypad etc. We would like to just use alarm with out phone service. It has a flashing FC code (communication failure). Is it possible to use the alarm without ADT? How can you shut off the FC ?
Old 05-03-08, 11:47 PM
Received 38 Votes on 37 Posts
Read through the FAQ for this topic, and read over the various posts about Ademco clone systems. In general, it's very easy to erase the ADT dialer numbers and make it a local system (FC means "Failure to communicate".
The odds are that you have a Safewatch 3000 which is a clone of the Ademco Vista 20P.
Old 05-04-08, 07:08 AM
It's up and running
It's a Vista 20. We got the box open. We even had lost the master code but used a "procedure" we found on the net to get it back. It's working now. No FC alarm anymore.
The only thing that is not functioning correctly is the motion detector. It will operate correctly but it won't set off the alarm. Only the doors set off the alarm.
If anyone know what's up with that. I can see the light on the motion come on. The keypad will recognize the ready /not ready state. But it won't set of the alarm.
Old 05-04-08, 09:48 AM
If you don't open and close the entry/exit door when you arm the system, the panel auto-bypasses interior devices like the motion. It's not a bug, it's an anti-false alarm feature.
Old 05-04-08, 10:31 PM
Thanks
Thanks... we'll test that out....
