Wiring Connectors ???
Old 05-04-08, 11:19 PM
R
Hi, New to this! And planing on wired system and wondering on the best way to make all the connections and splices from the different window and door switches? I would not want to go looking for a bad connection later!
Theres never enough time to do it right !
But theres always enough time to do it over?
Any Help is Greatfully Appreciated. Thank You!
Old 05-05-08, 04:40 AM
Received 241 Votes on 220 Posts
What you want are called "B" connectors (http://www.elkproducts.com/accessories.htm)
They come in dry and gel-filled. If you are doing splices in an inaccessible space like a wall void, I recommend the gel-filled, but either will do the job just fine. You can also use telcom "scotch-lock" crimps (which are actually a superior device, but are bulkier)
Old 05-06-08, 10:49 PM
R
Thanks , Is there special crimping tools needed?? Do the wires need to be stripped ?? Which are better the Gell Filled?? or Unfilled?? Thank You!
Old 05-07-08, 04:39 AM
Any of the standard electrical crimping pliers you can get at the home center will work just fine.
The B connectors say that the inner teeth will pierce the wire insulation, but it's better to strip the jacket. Gel filled is only worth the money for dampish environments. I often use them here in FL, because the humidity and salt in the air, even as far inland as I am, will eventually start the copper wire and the brass crimp metal to corroding.
