DSC PC1616 panel with RFK5501 ICON keypad
Old 05-26-08, 08:19 PM
E
I just installed the 16 zone panel with the RFK5501 keypad that has a wireless 32 zone receiver built-in.
I have enrolled the keypad as 11, and placed 3 wireless devices (2x WS4945 door xmitters and one WS4904P PIR). All of the devices were entered using the *8 [Installers Code]804, with 01 being the PIR, 02 and 03 the door xmitters. I tested all devices using the *8 [Installers Code]904, then 01, 02 and 03 for the devices. They all produced green flashes on the keypad.
I followed the Installation guide on page 29 and defined the zones *8 [Installers Code]001 as 01=01(delay), 02=01(delay) and 03=03(instant), all others (Zone 04 thru 16 as 00).
I set the partition 1 entry/exit times as *8 [Installers Code]005 01 030,030,030.
I set the bell cut off timer *8 [Installers Code]005 09 as 120.
When I set the alarm for Away Arm, none of the wireless sensors are noticed as I exit, and when I reenter after the delay.
What else do I need to do? Would it be easier to order the programming cable and do it with a PC?
Thanks for any insight!
Etype
Old 05-27-08, 04:26 AM
T
go into your attributes and turn on number 8 for wirless. *8,
installer code, 101 turn on 8, #, 102, turn on 8, #, 103, turn on 8, ##. that should fix you up? can i ask you a question? how come you have the pir as a delayed zone, just curious. also you have your bell set for 120 minutes. not sure if your away of this.
Old 05-27-08, 07:45 AM
E
Tallcanadian, thanks for the input!
The PIR is on delay because it overlaps the front door. If I don't delay it also, it will activate the alarm before I can shut down the system at the keypad.
If I activate these attributes, will the chime (pre-alarm) work also?
10 minutes for the bell...my neighbors thank you!
Etype
Old 05-27-08, 02:18 PM
T
*8, installer code, 102, turn on 3, #, then 103, turn on 3, ##. then push *4 or press and hold the chime key and get 5 or 6 quick beeps. make sure 101, the motion does not have 3 turned on or the chime will activate each time you walk past it.
