Vista 20P hardwire motion sensor issue and Zone Type issue
Old 06-19-08, 10:22 PM
I
Hi,
I'm new at this and I need some help here.
System overview
Vista 20P
6150rf
6160
5816x2
997
998PI
audora
EOL on Zone1,4,5,6,7,8. Also the same zone were disabled 00 in the *56 menu
Question 1: The 2 hardwire motion sensor (Zone 2 Audora and 3 998PI) did not work. It passes tests and ready to arm. However once I armed, I could not do anything to fail zone 2 and 3. The rest of the RF Zone9,10,11 work fine.
Question 2: I did not find any Zone Type that could match what I want. I want interior with out delay for my motion sensor. There is at least 2 motion that I want it response imediately with out delay.
Old 06-20-08, 05:47 AM
Received 103 Votes on 95 Posts
Where did you install the resistor on these devices? Did you put them in _series_ with the normally closed contact? If you put them in _parallel_ to the contact, you will never get an alarm activation.
The correct zone type is interior follower (04). These will be instant unless an entry/exit door has been activated first, and will auto-bypass if you do not open and close an entry exit door after arming.
Old 06-20-08, 08:18 AM
I
Hi MrRon
I did not use registor on the NC sensor. I thought I only have to use registor on the unuse slot. I'll put a registor in series with the NC sensor.
Zone Type 4 explaination is excellent. Now I got it.
Thank you very much
