Ademco 4110DL
Old 07-11-08, 07:08 PM
Ademco 4110DL
My mom just moved into a house and there is an existing ademco 4110DL system in the house.
But we do not have the Master Code, and the manufactures code from manual is no good, the system is already in armed mode. What is the best way to get this system defaulted i have no problem reprogramming the zones.
I did check and the horn was cut in the vent and as soon as i hooked it up it started with the siren
Thanks for the help
Old 07-11-08, 08:42 PM
Received 267 Upvotes on 246 Posts
Follow the procedure in the FAQ sticky for ademco panels: Remove AC power and battery, restore ac power and within 50 seconds, press * + # at the same time. Once in program mode press #20, and the panel will read back the master/programming code one digit at a time.
Old 07-12-08, 06:55 PM
V
If the panel does not go into programming, than it's most
likely locked out and you would either have to try and
get the master code from the installer, or replace the board.
Old 07-14-08, 11:31 AM
I attempted to contact the installer before posting on here but the company is no longer in business, and that kind of surprises me because the house is only 3 years old.
Old 07-14-08, 05:20 PM
The _house_ may be 3 years old; that 4110DL is from 1995 at it's _newest_(my copy of the manual is dated 1991). I suspect that this thing was either a backstock item; a transfer from an older residence, or a self install using auction site purchased hardware.
If it's been installer locked out, I recommend replacing it.
