"Low Bat" Vista 20p 6160 keypad
Old 07-16-08, 01:41 PM
I Just installed a brand new vista 20p (hw only) without a Battery Back-up (no battery)... I did however, connect an old battery from my old system for a few minutes just to see if it would hold the system.I can't seem to get rid of the "low bat" and chirp from my 6160. I have powered off & on...*63 says 63 even when I enter 00 & *99...I know it must be my bad eye,,,what am I missing here...thanks in advance
Old 07-16-08, 04:28 PM
kcxj's Avatar
The system will always look for a backup battery.
Old 07-16-08, 06:16 PM
So...... KC, I've been thinking alone that the vista could operate fine with no pwr back-up (as long as there are no pwr interuptions)...and you're saying I'll get that "system low bat" with a constant chirp if a battery is not connected to the system? No way to disable it and just run the vista on ac??
thanks
Old 07-16-08, 07:33 PM
kcxj's Avatar
That's correct, the panel needs the backup battery. I don't believe you can get around this.
Old 07-16-08, 08:05 PM
Received 35 Votes on 34 Posts
No, you cannot turn off the battery test. *63 only sets the monitoring report of the battery condition. Install a good battery.
Old 07-17-08, 06:14 PM
....glad I didn't bet anyone. Thanks very much
