PC5010 Programming
Old 10-15-08, 04:09 PM
A
PC5010 Programming
I have a PC5010 security system and the installer code. I've had a few problems over the last couple of weeks that I've solved with the help of some of the posts here.
I've gone out and downloaded all of the manuals for this system including the Programming Worksheets in order to be able to solve any future issues, which brings me to my question.
I was wondering if there is an easy way or procedure for me to step through the system from the touch pad and document via the Programming Worksheets all of the programmed information in the system?
Thanks
Anthony
Old 10-15-08, 05:51 PM
Received 267 Upvotes on 246 Posts
From the section of the manual titled "How to Program" (page 21):
4.5 Viewing Programming
4.5.1 LED Keypads
Any program Section can be viewed through the keypad. When a Section is entered the keypad will immediately
display the first digit of information programmed in that Section.
The keypad displays the information using a binary format where:
Zone Light 1 = 1
Zone Light 2 = 2
Zone Light 3 = 4
Zone Light 4 = 8
Add up the values for the zone lights to determine the number displayed (for example, no zone lights = 0, all 4
zone lights = 15 HEX ‘F’).
Press any of the Emergency Keys (Fire, Auxiliary or Panic) to advance to the next digit. When all the digits in a
Section have been viewed the panel will exit the Section, turn off the Ready Light, turn on the Armed light and
wait for the next three digit Section number to be entered. If the [#] key is pressed the panel will also exit the
Section.
4.5.2 LCD Keypad
Any program section can be viewed through the keypad. Depending on the section entered, the LCD will
display the information differently as below:
Sections Entered LCD Display
Phone number ..................... Entire phone number
Partition identifier code ....... Entire partition identifier code
Toggle option ...................... Entire section (all options)
Reporting code ................... Each 2-digit reporting code at a time
Use the arrow keys () to scroll through the data being displayed.
Scroll past the end of the data displayed or press the [#] key to exit the Section.
