alarm system master code reset
Old 11-25-08, 04:50 PM
Hi, i have an alarm system that has been sitting in my work shop for a while, i just built myself a workshop and i would like to install the alarm system in it, the problem is that i don't have the master code, how can i reset the old code so i can put a new one in. the system is a dsc 1500.
thanks
Old 11-26-08, 03:57 PM
Received 88 Votes on 83 Posts
You can try the default installer code: *8 1500. If it goes into program mode, you can extract/change the mastercode.
If not, you will need to default the panel. In either case you will need the installer manual.
http://www.bal-tech.ca/PDF/PC1500_v4-0_EN.pdf
Yes, it is not intuitive or easy reading, but all of the info is there. The instructions for defaulting the system are on page 17.
Old 11-28-08, 04:12 PM
thank you very much MrRonFl, i followed the link you provided, got the instructions and did the programming worked like a charm.
