DSC PC5508Z keypad has very low beeps volume
Old 12-12-08, 01:06 PM
E
this is about 5 year old home alarm professionally installed, with no problems up to now.
Two keypads are installed. One of them has developped very low beep / chime volume and it cannot be adjusted (as per the manual) any higher.
I have found a reasonably priced new keypad and it looks like a easy job to replace.
Question: is the keypad a probable problem? and if so, can it be just changed without any programing?
thanks for your help.
Old 12-12-08, 02:52 PM
Received 92 Votes on 85 Posts
DSC keypads require programming. You have to set them to an address, and you have to re-run the module supervision, or the panel will go into trouble looking for the "missing" keypad.
(you will need the installer code for this)
