Adding a new user code to my vista 20p w/ 6160 keypad
Old 12-22-08, 06:44 PM
G
Can someone give me step by step instruction to add a new user code for my neighbor to use. I have followed the manual step by step, but I must be missins something.
Old 12-22-08, 07:53 PM
PRO1 TECH's Avatar
Master code + [8] + user no. + new user’s code
Master code + [8] + 05 + new user’s code
Old 12-22-08, 08:27 PM
Received 288 Upvotes on 265 Posts
The biggest trick is that you cannot hesitate more than a couple of seconds between keystrokes or the system kicks back out of code programming and it doesn't take.
Write it out so that you can key it in smoothly.
Old 12-22-08, 09:35 PM
G
Thanks for the replys!
looking at the keypad "disarmed ready to arm"
security code + 8 + 05 + new code
Nothing happens!
Old 12-23-08, 04:52 AM
PRO1 TECH's Avatar
Nothing happens!
you need the master code not a security code your master code my need to be reset if you don't know it
we can help you if this is so
Old 12-23-08, 06:43 AM
G
Sorry
I'm using the master code.
Old 12-23-08, 11:19 AM
That's the keystroke sequence: [master code] + 8 + [2digit user #] + [new 4 digit code]. That's it. No voodoo, no rubbing blue mud into your belly button.
As far as I know, there is no way to disable the ability of the master code to set sub codes. See your user manual.
