Change 6150 keypad to a 6160
Old 04-16-09, 12:28 PM
I have an ademco 20p alarm system with a 6150 keypad and would like to upgrade to a 6160. All are hardwired. Will this require any programming for new keypad or is it a straight unwire old and replace with the new?
Thanks
Old 04-16-09, 03:09 PM
T
6160 is compatiable for vista 20p
Old 04-18-09, 06:36 AM
W
Replace a 6139 keypad with a 6160
This is a great site. What would have taken me weeks to figure out takes only a few hours. As MrRon has told many would be necessary, to get the programming capability I'm looking for, I am awaiting delivery of a 6160 keypad. I'm looking forward to installing it but am hoping it doesn't turn out to be more complicated than I'm expecting.
Here's some background. I have an ADT Safewatch Pro 2000 system which I understand from this site is a Vista-20SE. The 6139 keypad is fixed text which isn't good enough for doing anything other than turning the system on and off.
In this thread, there was a response that the 6160 is compatible. Not exactly sure what that means. 1) Does it mean, remove wires from old remote and install them on the appropriate terminals of the 6160? 2) Is there any additional initialization/programming necessary - I assume there is to for example register the new text fields? 3) Will this all be documented in the 6160 user manual?
Also, I have to of course remove my 6139 keypad. I see 2 tabs on the top edge that appear to release the front face plate but they sure are difficult to push in. As it's all plastic, if I push much harder I'm expecting the whole case to crack or worse I'll rip the whole unit off my wall. 4) Any advise how to do this?
Sorry for the long note. I've asked 4 questions which have a number (1 to 4) in front of them. To simplify your response, feel free to just reference the questions by their number.
Thank you in advance.
Old 04-18-09, 07:37 PM
Received 265 Upvotes on 244 Posts
Since you are replacing a 6139 with a 6160 (compatible means that Ademco lists this working with a Vista 20se/SW 2000), the new keypad should work right out of the box. You just swap wire for wire.
The keypad text on Ademco panels is stored in the alarm control. The keypad is just a display, so your existing text should be displayed.
The manual you really should be reading is the one for the Vista 20se:
http://alpinealarms.com/ademco/v20seim.pdf
Old 04-21-09, 06:29 PM
You can't program with the 6139?
I thought the 6139 was good for programming as well as the 6160?
Old 04-22-09, 09:31 AM
W
To help ensure this thread doesn't cause unnecessary confusion in the future, my old keypad was actually a 6137B. I quoted 6139 in error. Sorry about that.
If anyone out there is thinking of upgrading, I can tell you it was one of the easiest installs I've ever one. There will actually be more work painting the wall (new key pad covers different space than my old one). I certainly can live with that.
Thank you all, especially Mr Ron for all the info/advise.
Old 01-06-10, 01:54 PM
Sorry to dig up an old thread. I was wondering, if I want to add a second control panel (6160) to my existing 6160 and 15p setup, can I just run wires to the same connection terminals that my current 6160 goes, and it will work fine out of the box? OR do I have to configure the second panel after installing it?
I ask because my dealer wants $200 to install this second panel and that seems high since I can just buy the second panel myself for well under $100.
Old 01-06-10, 05:09 PM
F
Smile
As long as your panel doesn't have installer lockout you can add the keypad yourself. All keypads have a specific address that must be assigned. You have to assign the keypad an address then you have to turn that address on in the installers programming.
First step would be to see if you can get into the panels programming. Follow MrRons stickey in the forum that reads " read before posting". It will tell you how to get into programming for your panel. If you are successful then you have the option of being able to do this job on your own with out the installation company. Lets us know.
Old 01-06-10, 05:15 PM
Ok will do, thanks, I'll get back to ya.
