Exit button "function not available"
Old 05-04-09, 04:10 PM
T
Hi folks. I have an older power series ( can't remember if it's 832 or 864) and apparently the exit button is not programmed.
Can someone give me a quick step by step.
I was told to hit *8, installers code, then section 015
Once I do that, all I see is some numbers and hyphens.
Am I on the right track here?
Thanks in advance.
Old 05-04-09, 06:25 PM
A
Should have manual to follow
After you follow those steps, if three is not on, press three and it should light. Then exit programming. The only other reason it wouldn't work would be that the function button programming is not set. But do the above first.
Old 05-05-09, 03:06 PM
T
Thanks AllTrack.....it worked like a charm
