DSC power 832 security system
Old 05-09-09, 08:51 PM
R
I have a DSC power 832 security system and when performing the factory default I can not get the zone 1 light to come on indicating the factory default has been completed. What could the problem be. Thanks, rick r
Old 05-09-09, 08:55 PM
R
Old 05-09-09, 10:20 PM
A
Are you pressing 999 twice? It's 999 Installer code then 999 again.
Old 05-10-09, 08:55 AM
Received 89 Votes on 83 Posts
If you are following the procedure from the installer manual:
"Factory Default Main Panel (Hardware)
Step 1 - Remove AC and battery from the panel.
Step 2 - Remove all wires from the Zone 1 and PGM1 terminals.
Step 3 - With a piece of wire short the Zone 1 terminal to the PGM1 terminal.
Step 4 - Apply AC power to the main panel.
Step 5 - When Zone Light 1 is lit on the keypad the default is complete.
Step 6 - Remove AC power from the control
Step 7 - Reconnect all original wiring and power up the control."
Even if the installer lockout is set, it will default everything _except_ the installer code (you did check for the 10 clicks?).
Old 05-12-09, 11:33 AM
D
DSC Power 832
We purchased a house with this alarm system and were not given any information about it. Previous owner doesn't know anything :-(
Any suggestions about determining the master code or resetting it?
Old 05-12-09, 12:34 PM
If you don't have the master code or the installer code, the only choice is to do a hardware default, which may not work if the installer lockout was set.
You need both installer manuals _and _ programming forms; the instructions refer back and forth between them. Read especially the section titled: "How to Program"
Installer manual: http://www.homesecuritypro.us/manual.../P832_iman.pdf
Programming Forms: http://www.homesecuritypro.us/manual...gramsheets.pdf
Read over the sticky titled "Alarm Forum FAQ: Please read before posting" This system and it's siblings are a common topic on these forums.
