6150adt keypads??
Old 05-12-09, 08:27 PM
E
6150adt keypads??
I installed a safewatch pro adt 3000 in my home. I purchaced the unit off of ebay. I had an alarm tech from a monitoring co (not ADT)program my system with his own keypad I believe it was a 6139. This alarm box came with two keypads 6150ADT that were in plastic and in a box and appeared to be new. The tech was not able to get those keypads to work the keypad screens show blank. Is there anything I can do to get the 6150adt keypads to communicate with the panel? If I have to buy new keypads what keypads should I purchase. The book that came with this panel said it needed 6150adt and 6160adt. If the 6150adt keypad that came with the alarm does not work BUT the 6139 did. Does anyone have any suggestions?
Old 05-13-09, 04:10 AM
Received 89 Votes on 83 Posts
The SW 3000 is a slightly modified Vista 20p. There's no special magic about the ADT labeled keypads. Your most likely issue is that the keypads need to be addressed and the addresses need to be activated in the system programming.
http://www.alarmeengros.com/installation15P.pdf
Old 05-13-09, 07:22 AM
E
keypads
Thank's for the help. I followed the directions from the link you provided and I was able to get one of the keypads to operate.
I turned off the power,
Then I turned it back on
I held keys 1 and 3 down and zeroed the address
On the first keypad I entered address 16 and then *
(it worked) on the first keypad at address 16
I went through the same sequence for the second keypad except I entered 17 and then * but no luck. Still a blank screen on the second keypad.
Old 05-13-09, 11:56 AM
kcxj's Avatar
Did you enable keypad address 17, this has to be done in programming for the second keypad to work.
Old 05-13-09, 01:46 PM
E
6150 keypad
I read that address 17 had to be enabled in field 190. Can this be done with the 6150 or do I need a 6139/6160 alpha keypad to enable address 17?
Old 05-13-09, 01:51 PM
kcxj's Avatar
This can be done with a 6150
Old 05-13-09, 02:39 PM
HotxxxxxxxOKC's Avatar
Alarm tech did not know how to address a keypad? ouch.
Old 05-13-09, 06:13 PM
E
6150 keypads
Thank's for this great forum. I was able to muddle my way through and get it done.
