Setting Date & Time for Scheduling VISTA 15p with fixed char display
Old 05-13-09, 07:44 AM
G
Hello,
I have a Vista 15p with FIXED CHARACTER display (non-Alpha). Is it possible to set date and time with this keypad, or is an alpha absolutely necessary? Judging by the instructions I have, alpha is needed (but it doesn't specifically state this...)
I want to use scheduling to set to STAY mode automatically, hence the need for date/time setting...
Anyone?
Old 05-13-09, 02:38 PM
Received 88 Votes on 83 Posts
You need a 6139/6160 keypad to use the scheduling feature.
If it's under menu mode programming in the manual, you need a alpha keypad to do it.
Old 05-13-09, 03:02 PM
G
Thanks for the response. Bummer!
To be clear, there is no way to even do a 'blind' set up using the non-alpha keypad?
Thanks!
Old 05-13-09, 05:51 PM
Too many variables, and you cannot even _activate_ the scheduling without an alpha keypad.
Enrolling a zone or two is doable blind, most of the other menu mode programming is right out.
