X-10 and ademco Vista 20P
Old 05-13-09, 12:39 PM
D
Hi,
I am trying to setup 2 x-10 socket rockets with my vista 20p panel. I have the 1361X10 transformer installed, 2 socket rocket lamp plugs. Can someone tell me how to proceed next ?
I do not have any other x-10 devices. I was wondering how to make the xformer identify the two socket rocket lamps?
Thanks,
Sudhir
Old 05-13-09, 02:53 PM
Received 90 Votes on 84 Posts
First, if you don't already have one you need the installer manual.
Most of this requires a 6160 keypad, or equivalent because you have to be able to see the menu prompts.
Give the sockets their individual addresses between 1-8
In system programming location *27, set your house ID
In *79 menu mode:
{Prompt} Enter output NO.
(enter 1 since this is the first output you are trying to program)
{Prompt} XX Output Type
(enter 2 for power line carrier device)
{Prompt}Unit No.
(enter the unit code you set at the first device)
It will go back to the output number prompt, and you "lather, rinse and repeat" for the next device
After you do the second one press 00 to exit *79
NEXT
You define what you want the output functions to do in *80.
Read over those instructions and see if you have any questions. There are too many variables there to just give you a boiler plate. You actually have to make decisions.
