ADT Safewatch 3000 Pro
Old 05-18-09, 04:39 PM
H
Hello. I'd like to disable the voice feature of the keypad on my Safewatch 3000 Pro. I checked the box in the basement and it is in fact, a Safewatch 3000 Pro. Thanks in advance.
Old 05-18-09, 04:54 PM
Received 89 Votes on 83 Posts
I'm with you, I find the "voice" used on these keypads more annoying than helpful. I think it was really intended for the visually impared.
In any case:
Pop the keypad off of it's mounting plate. Disconnect the black wire wait a few seconds, and then reconnect it.
Within 30 seconds of reconnection press 1 & 3 at the same time.
It will display the current keypad address; just press * to accept it.
The next prompt is for voice chime mode. To turn it off, press 0*. Then press * until you exit keypad programming, or ignore it for a couple of minutes and it will exit on it's own.
It will still use the voice for alarm annunciation, but it will use a normal chime for the door and window chime feature.
If you have any questions, refer to the installation sheets:
http://alpinealarms.com/videos/manuals/6160vim.pdf
Old 05-21-09, 05:29 PM
G
or simply press #024 outside of progaming
