Moving - What Settings Need To Be Changed on DSC832
Old 05-19-09, 04:45 AM
C
Hi,
I have a DSC Power832 / PC5010 system and I use a VoIP monitoring company called NextAlarm.
I have the Installer Code and I made the programming changes required to communicate with NextAlarm after I quit using the original installer and monitoring company (independent company who installed alarm that came with new house).
We sold our house and will be closing in a month...I would like to know what settings I need to change to remove any personal account info and to ensure the system is not trying to dial out to NextAlarm, and that the alarm will be usable by the people buying the house.
In reading the FAQ, I will have to turn the Communicator and TLM off by entering programming, turning off option 7 in section 015, and option 1 in section 380.
What else do I need to do?
Thanks so much - The few questions I had when setting up my VoIP monitoring a couple of years ago were answered quickly and correctly on this forum - so it is the first place I go when I have any questions regarding alarm systems!!
Old 05-19-09, 07:04 PM
A
Sounds good. I would also blank out any receiver phone numbers (Locations 301, 302 & 303) Account Numbers (Locations 310 & 311) and set Master Code (Location 007) to 1234.
Old 05-19-09, 07:29 PM
Received 88 Votes on 83 Posts
Also, set the installer code back to 5555 (the factory default).
You will be doing the next owner a big favor.
Old 05-19-09, 08:58 PM
LOCKtec's Avatar
FYI
the POWER 832 5010 systems used 5010 as the installer codes- not 5555
Old 05-20-09, 04:51 AM
Good catch! That was the last one that they used the model number for the code, before they went to 5555 for all models.
Got on a roll...
Old 05-20-09, 09:15 AM
C
Thanks for the advice...
I have the installer code from the original installation contractor, but where do I change it back to 5010?
Old 05-20-09, 04:23 PM
*8 [installer code] 006 5010
Then press # until you exit programming.
