Adding 5820L Sensor to Vista 20P
Old 05-28-09, 02:17 PM
C
Hi,
I bought a few 5820 sensors from ebay, and am trying to figure out how to configure them with the Vista 20P.
Regards,
Abrar
Old 05-28-09, 02:40 PM
Received 90 Votes on 84 Posts
Do you have the installer code?
Do you have the installer manual?
Do you have a 2-line alpha keypad (6139 or 6160 or equivalent)?
Do you have a wireless receiver?
Getting the installer code and manual isn't tough; but if you don't have both of the last two items, then you are stuck.
Old 06-01-09, 06:01 PM
C
Hi,
I have two windows that have wireless contacts as well. So based on the answers below is it do-able?
Do you have the installer code? --Yes
Do you have the installer manual? --No
Do you have a 2-line alpha keypad (6139 or 6160 or equivalent)? --YES
Do you have a wireless receiver? --yes
Old 06-01-09, 06:30 PM
Manual is easy; just plug the following phrase into your favorite search engine: "Vista 20p installer manual" (this is, of course, assuming that you _have_ a Vista 20p...) You should hit a PDF in the first 2 or 3 hits.
Other than the section on system programming; the main thing to get familiar with is the section on *56 mode programming.
