Replacing vista keypad on ademco 4140xmp
Hello
I have looked around the forums but still am a bit confused so I hope I can get a little help. I have been tasked with replacing a failing vista (4137) keypad on a Ademco 4140 xmp alarm. My understanding is that if I replace the keypad with a newer but obviously compatible vista keypad it is a matter of simply swapping out the keypad. But from other threads on the forum it seems I have to make sure that I purchase a keypad that has all the right features in order to still be able to program the unit. So my question is which keypad do I get?
We also have to replace door sensors which I assume is a simple matter of swaping the old for new ones. (Please Let me know if I am mistaken)
On the main board I found the numbers SA4142 and W2315 I did not know if those numbers would be useful in getting any info.
One last thing is it better to replace the keypad and sensors or just buy a whole new setup? Some of the keypads seem to be as expensive as a whole kit. I have seen the ademco 20P for as little as 169 on Ebay. Mind you I am not sure if it is a good system I simply use it as a guide since what we have at this time is also an Ademco system.
I certainly would appreciate any help on this matter.
Thanks in advance for your assistance.
Ed
Ed
