DSC Power 832 - Program to Call Cell Phone?
Received 0 Votes
I have searched every where for this information but can't find it. I have discontinued our alarm monitoring service and would like to have the alarm ring my cell phone when it is activated. It appears that it can be done? Can you please assist? Or point me in the right direction. (our previous monitoring service was ADT if that helps....)
Cheers
Cheers
To do this, you need to know the installer code. I don't know if the Australian ADT uses the same installer code commonly used in N. America.
You would need to change the reporting format to "pager". Yours being an overseas model, you _may_ have the option of "residential dial".
Websearch using the phrase: "DSC PC5010 installer manual" _and_ "DSC PC5010 programming manual". You need both.
Check your actual model number (either on the wiring diagram on the system enclosure door, or printed on the large IC chip in the center of the motherboard). Many of the non-N.A. models have significant programming differences.
