PC5508Z DSC Power632 Program new master code without having current master code
Old 08-30-09, 10:46 AM
re: PC5508Z DSC Power632
How can I program a new master code without having the current master code? I'd like to disarm the system but I believe I need the master code in order to get it done. The alarm sounds when we open either of our outside doors and we just want to make it stop.
I know absolutely nothing about alarm systems (came with the house and we haven't used it so far) so please keep that in mind when replying. Help would be VERY much appreciated.
Old 08-30-09, 12:08 PM
Received 36 Votes on 35 Posts
If this system is armed and the factory default code (1234) doesn't work, the only thing you can try is a hardwire default of the system. (outlined in the sticky titled: "Alarm Forum FAQ: Please read before posting")
You need the installer and programming manuals. Websearch using the phrases "DSC PC5010 installer manual" _and_ "DSC PC5010 programming manual", you need both, because if you use the default, you will have to reprogram _everything_.
