Security camera installation-wireless or wired
Old 09-29-09, 11:59 AM
I have a small farm with several outbuidings at least 1,000 feet from the house. I would like to have 4 cameras, motion activated, mounted at different locations. Should they be hard-wired for better quality or wireless?
Old 09-29-09, 12:35 PM
kcxj's Avatar
I would do hardwired. You will need to trench and run conduit, but it will be more reliable and less constly than a wireless transmitters and receivers.
Old 09-29-09, 04:29 PM
Hardwire for sure. You will have too many issues with wireless. 1000' is no problem. You can use cat 5 with balons on both ends.
Old 10-01-09, 07:14 AM
Thanks, but I have several sidewalks so would overhead be just as well?
Old 10-01-09, 08:38 AM
If the wire an be attached securely, sure. I have ran both cat 5 and rg59 (video cable) this way and have had no issues with either.
Old 10-07-09, 06:09 PM
Go wired
Definitely go wired and if runs are more then 400 ft use cat5 and balons. Never go wireless it simply wont work (I don,t even know why they make am). In your situation wiring will be a lot of work but trust me at the and of the day, it will be worth it.
The motion detection is actually build into most DVR systems and has nothing to do with cameras. Use any camera you like and enable motion detection in DVR setup.
cctv systems and intercom repair
Old 10-13-09, 06:12 PM
I am with everyone else. Go with hard-wired. Its the only way to go. On another note, if you are going to run wires overhead, I would still use "direct burial" rated wire, it may cost a little more, but it is weather rated and is simply cheap insurance for the longevity of the cable against the elements.
Old 10-16-09, 04:06 PM
Thanks
Thank you. You know, when one has never did a project before, one needs all the help and advice as possible. This is what is so nice about the site.
Old 10-16-09, 04:10 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
how wide are the sidewalks? Unless they are more extremely wide, I would still run underground. Getting under a sidewalk is not that difficult, usually.
