Help with Ademco Via 30+
Hi....
I thought I was doing quite well in managing to enter Programming mode, and disabling a zone that I no longer needed.
However, when I exited programming using *99, and triggered the alarm using an active zone to test the system, I find that it no longer dials the central station - which it was doing earlier today.
I recall seeing a prompt for 'Primary Phone' at one point. Could I have inadvertently erased the central station number (I didn't make any entries)?
If so, can it be restored from memory?
If not, do I enter the local 7 digit number only? or, if an area code is required, do I prefix it with a '1'?
Thanks
Thanks
When you entered *41, the next digit you entered before pressing * again overwrote the telephone number.
The standard way to disable the ademco dialer is *41* and *42* which deletes the primary and secondary phone numbers.
