Ademco 4110 Faulted Zone
Hello-
I am trying to test/activate this system which was pre-existing in the condo that I just purchased.
When I run the standard test, it reads 01 not ready. There is only one zone installed in the condo.
How do I restore the faulted zone?
The motion detector on the zone seems to be working properly.
Thank you very much.
Take a look at the terminals on the motherboard in the box with the battery, if there are wires on the zone terminals, then you probably have more zones than you think you do.
Typically zone 1 will be the main entry door(s). You probably have a bad contact or a missing contact magnet. Look at the edges of the door frame, there should be a small round contact in the door frame with a matching magnet on the door itself.
