DSC PC1555 / LCD5501Z32-433 System Died
My alarm system stopped working. I've started troubleshooting and noticed the PC1555 AUX+/AUX- voltage is only a few mVDC when the keypad is connected and 13VDC when the keypad is disconnected. I checked the resistance across these terminals on the keypad and it is practically a short. Is this typically how a keypad fails?
disconnect the wires from the panel that go to the keypad.
is there only 1 ??
then get a short piece of 4 cond wire & connect it standing in front of the box- see if it works then.... if so, there is a short in the wire going to the keypad from the panel somewhere.
is there only 1 ??
Thanks LOCKtec for your reply. I left out a detail in my description - I disconnected all of the wires from the keypad and am checking the resistance across the terminals of the keypad. This is where I'm seeing the short.
