Adding a water/flood sensor to a Concord 4
Hi all,
I'm in the process of adding a couple of water/flood sensors (GRI 2600) to my existing Concord 4 system. They are all hooked up hardware-wise, now I'm trying to determine which group to place them in to get the following desired behavior:
When they trip I would like the system to give me an indication of the problem, but not fly off in a panic. A periodic beep/chirp and possibly a voice announcement would be perfect. I would like this notification to repeat every few minutes or so (1/3/5/10/etc minutes - don't really care about the actual period), but not be continuous and not set off any of the alarm modes. I would also prefer if it would reset after the condition goes away (after I pull the sensor out of the water and start addressing the problem).
I began by learning them into Group 19 (Freeze sensor) - but when they trip that group is setting off the Auxiliary alarm and basically just raising holy hell.
I next tried Group 25 (Local Special Chime) and that produces a much better notification, but as far as I can tell it only notifies when the sensors first trip and doesn't repeat as long as the condition continues to exist.
I there something similar to the default Group 25 that will continue to notify periodically as long as the sensor remains tripped?
Thanks in advance for any suggestions.
--Ralph
--Ralph
Group 25 is going to get you the closest to what you want...
You could play around with output programming and hook up a sounder and program it to go off for X amount of time every time that sensor or better yet, any sensor in that sensor group (25) goes off...
That's what I was afraid of. In that case I'll probably look into adding a small circuit to the sensor loop to turn the continuous signal from the sensors themselves into a periodic signal to the alarm panel.
Thanks for the reply!
--Ralph
--Ralph
