superbus 2000 - reset password??
Old 09-18-10, 11:12 PM
H
Received 1 Upvote on 1 Post
bought a house recently and homeowner never used adt alarm system from there previous owner, so i have this 2 year old ADT alarm system with no code, dc adapter and battery was unhooked, when i hooked them up panel came on and said armed to away, as if its been armed for 2 years, just had no power, after about 30 sec, alarm went off and had to disconnect power again. i read on other forums holding * and # while powering up to enter programming mode but its not working. ive tried several times, wont enter mode and i cant press anything else or else it will ask for password. i know my programmers code is 6321 because it says it in the box, which is a concord. please someone help me reset the password so i can use this.
superbus 2000 GE4006 panel
concord box
Thanks
Old 09-19-10, 09:30 AM
kcxj's Avatar
You can try to disarm with a known duress code: 2580. Enter 1+2580. Once disarmed you should be able to change the master code with the installer code.
Old 09-19-10, 11:36 AM
H
it worked, thankyou.... but now that worries me, can that same code be used by lets say.... a thief?
Old 09-19-10, 12:12 PM
H
sorry i did not try to reset password before posting "it worked"
the password you gave me worked to disarm system so i can get into menu, now can someone give me a list of source codes, for the superbus 2000? the ones i found on forums are for another system not this one.
Old 09-19-10, 06:24 PM
Received 267 Upvotes on 246 Posts
Superbus 2000 is the keypad model. What is the model of the _alarm control_? There are multiple versions of the concord family that use those keypads.
What's on the diagram on the inside of the system enclosure door.
It's not an "ADT" alarm. It's a GE Concord (of some type) with an ADT logo and minor modifications.
Old 09-19-10, 06:25 PM
H
still no source code list from anyone? i cant navigate programming menu without them.
