DSC PC1500 new question
Old 10-06-10, 01:37 PM
I have a dsc pc 1500. The alarm works well but I seem to get the exit/enrty chime on the delay to sound off.Please help!!!!! Thank you.
Old 10-07-10, 03:02 PM
Received 267 Upvotes on 246 Posts
Ok, I'm sorry but your question is a little confusing. I honestly cannot figure out _what_ you are trying to get the system to do (or not do...)
Old 10-12-10, 06:38 PM
trouble shooting alarm
sorry about the last post, but i have a dsc 1500. everything works right but when we set it to "armed" and walk out the door, there is no alert noise ( chime noise ) like an alarm telling you to get out. Whe i eneter my security code, it will go straight into armed but you won't hear any noise... also, there is no trouble signs. this all happend after a lightning storm and lost all memory, so i had to change my code from "1,2,3,4" to a new code. thats when i expirienced the problem with the alert noise.. i went out and bought a new battery, but still no noise. thank you.
Old 10-13-10, 04:10 PM
Only the later versions of the PC 1500 had an exit audible feature. If yours once did, but now doesn't, it almost sounds like your system got reset to factory default.
If you have access to system programming turn ON option 1 in programming location 34.
Old 10-15-10, 07:23 AM
dsc 1500
Is thier a way to unlock a dsc1500 . mine is locked out thanks
Old 10-15-10, 03:06 PM
In the sticky titled "Alarm Forum FAQ (Please read before posting), there is a set of instructions that will bypass the installer lockout on _most_ versions of the PC 1500/1550.
