Replace a DSC PC5508 keypad
Old 01-02-11, 11:33 AM
D
I want to replace a DSC PC5508 keypad with a DSC PK5508 keypad. Can I simply disconnect the old keypad and connect the new one, following the same wireing? Or, will I need an installer code to make the change?
Old 01-02-11, 05:48 PM
Received 92 Votes on 85 Posts
You also need to set the correct keypad address, and run the routine that supervises the the new keypad, and deletes the old one; so yes, you need the installer code.
What is the base system you are connecting this keypad to?
Old 01-02-11, 08:43 PM
D
The base system is a PC5010. I found two installer codes in 3 different installation manuals I found on line. Two were 5555 and one was 5150. What do I do if these have been changed? Is there a way to get the change from the system?
I have two PC 5508 keypads. I'm replacing only one of the two with a PK5508, which is supposed to be compatable with the system.
Thanks for your help.
Old 01-02-11, 08:52 PM
D
OOPS! I forgot to ask how I can determine the address of the keypad I remove.
Thanks again.
Old 01-02-11, 09:04 PM
D
Coprrectyion, the second installer code was 5010, not 5150. Sorry.
Old 01-03-11, 04:29 AM
If the installer code has been changed from the factory default; then the only way to get at it is to default the alarm control. Even then, there is a possibility of the installer lockout having been used.
Read through the sticky titled "Alarm Forum FAQ (Please read before posting)". This is one of the more common system models, and a lot of your questions get asked about 2-3 times a week.
There is a DSC downloader software that can get into the panel (again, _usually_); but it can be fussy to get configured and working.
Old 01-03-11, 05:10 PM
LOCKtec's Avatar
how many keypads do you currently have ??
if you only have -1-, then chances are it doesnt matter
hook it up, while the other is NOT connected & see what happens. if no trouble light, after a few mins- then your good to go
unless your using the ZONE input, or PGM output terminals on the keypad, or the built in LOW temp sensor, then the address only matters for supervision, and most installers do not program this
