Home Security Upgrade - Ademco N5976v1 - Wireless?
Old 04-15-11, 03:10 PM
R
I currently have an Ademco N5976V1 control panel. I recently had a new door installed and have been advised that I need to go with a wireless sensor for that door, in order to keep the warrenty intact. From what I understand I need a wireless "cross connect", and obviously a sensor. Are these difficult to install, and what type of equipment is compatible. I have searched the web unsuccessfully.
Thanks for any input.
Old 04-16-11, 05:32 PM
Received 92 Votes on 85 Posts
That part number is the part number for the plastic shell on the keypad. To get your _system_ model, you need to open the metal box where the battery and motherboard are.
If your system already has a wireless receiver, you will be wanting (most likely) a Honeywell/Ademco 5800 series transmitter. To be more precise, you have to determine what your actual system and wireless receiver model are (the keypad _may_ be the receiver. Annoyingly, Honeywell puts the keypad model number on the _back_ of the keypad mounting plate.
